underdrive pully
johnvtls1
Melton,Victoria
E92 BWM 335I
not totally stock, it has tri Y HM extractors and a wet shot of NOS
but it is un tuned. im going to have it dyno tuned when i get some more money saved up
thanks 4 ur help
huh? you have nos hooked up and not tunned?? surly you cant use nos and not have any tuning?
mat vsII
34
mornigton penisula VIC
WK statesman 5.7, VS exec TURBO
why not?
it has to be tuned for a dry shot coz u need more fuel to be injected to stop it leaning out.
but with a wet shot of nos the extra fuel is mixed with the nitrouse in the fogger and its all sucked through the throttle body pre mixed
johnvtls1
Melton,Victoria
E92 BWM 335I
why not?
ah k fair enuf. i dont know too much about nos but didnt think that would be safe to do but all good.
mat vsII
34
Yeah that's ok. Wet shots are very simple and prety safe. U can put a wet shot on pretty much anything without tuning or doing any other mods.
walesy
Aint no family cruiser!!!
34
Perth SOR
Cherry Black WH II Caprice, VS exec wagon
i got a 25% underdriven pulley but its not on the car yet im strugglin to get the stock one off haha... 1735kg??? are you sure?? i doubt its that much lighter than the wh...
mat vsII
34
yeah, I just ran outside to make sure tho, and it is 1735. How heavy is the wh?
mat vsII
34
Just been doing a few searches on google at ur wh's kerb weight and it's the same as my WK 1735. And that was on a few different sites.
But correct me if I'm wrong.
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
you also have to have your car tuned to suit the nitrous when you arm the nitrous it plays with your timing so you dont detonate your engine
BradSV8
Nitrous Junkie
42
VY SV8
Personally I wouldn't bother with an underdrive. The only reason I fitted 1 was because it had to come off to put the cam in. It isnt worth the $$ and time to fit to gain maybe 5 rwkw. You would be much better off getting the car tuned and set up properly on the NOS. Also with a wet sys make sure you REGULARLY check your leads and plugs cause a NOS backfire isn't good.....
Brad
mat vsII
34
thanks 4 ur input, i will ive it a miss and just put that money towards the edit.
