Unknown Warning Chime - WHAT IS IT ?
Discussion in 'VE Holden Commodore (2006 - 2013)' started by ansett727rma, Oct 3, 2008.
  1. ansett727rma
    ansett727rma New Member
    2007 VE Omega
    I have a 2007 VE Omega. Every so often whilst driving, the warning chime goes off, with a momentary change in the display screen, then everything goes back to normal. The warning displays so quick that we have not been able to see what it says. The overspeed is not on. I have read the owners manual and cannot see what this particular warning could be. There is no residual message left on the bottom of the screen as states happens for most warnings. The car appears to be operating normally, and there appears to be no pattern as to when the warning appears.
    Has any one had a similiar problem?
  2. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    its when a subsystem fault code is logged into its control unit, it will display it on the dash for a split second and then act normally... if you got your fault codes checked at your next service you will see about 10 codes logged but not present
  3. ansett727rma
    2007 VE Omega
    VE Error Codes
    Can the codes be read similar to my old VS. If so how can they be read on the VE, and is there a list of codes available?
  4. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    no you need a compatible scan tool or tech 2
  5. happyhoppy
    happyhoppy New Member
    unima
    vt series one
    How do you replace the warning chime in VT. Drove with the handbrake on and no warning chime. Just bought it.
  6. Troy711
    Canberra, ACT
    2011 Mitsubishi Pajero GLS
    ^^^ lol, learn to check the thread age (and subject) before you post mate.
  7. Haluigi
    Haluigi New Member
    Morayfield
    2010 ssv g8 ute
    At least the search button works haha
  8. Fekason
    Fekason Fekason
    Penrith NSW
    CD Error?
    Hi,
    I have had an irregular warning chime that sounds similar. I eventually got to see what it was, and it was a CD error. The CD ejected, and then re-entered and all was OK. Only happened when CD was not playing.
    Maybe yours is the same.
