Upgrade Things for LPG System
ufo8mycow
www.facebook.com
VF
Hey Guys
Sure this has been asked before. Got a VS Calais 97 with 200K on the clock.
It was recently converted to gas..
Everything on the Motor is still Stock.
What do i need to replace to assist with the Gas Conversion, running better, etc etc.. What spark plugs i should be using, leads... etc etc
I dont know what brands i should be buying either so all suggestions are welcome.
mrhotdog
What Would Jesus Do?.....
Adelaide, South Australia
2003 VY S1 Acclaim
ive got a vs on gas, some say u need to change the spark plug gap but mine are standard gap, ignition system needs to be in good order, maybe just a fresh set of leads and plugs if it hasnt had them in a while, otherwise you may get backfire, some also recomend a flash-lube system (i dont have one) but it needs to be run on petrol reguarly to keep everything lubed up. gas runs hotter but if ur cooling system is good i wouldnt worry
gobrien002
1995 VR Series II S
be sure to get a good tune aswell!
