Im not too sure you can swap the series 3 v8 into a vs commodore. Since they are the same 5 litre that was in the VT, and you must go to fair troubles to get the VT 5 litre to work in a pre Vt commy. I think the troubles are that to use the current harnesses in your car, you need a pre-VT dizzy, and in doing so you will forfeit sequential injection. To keep the sequential injection I think you pretty much have to rewire the entire car to suit the comp. I would highly recommend finding someone who has done this converion, I think you also have to slice open one of the looms, since they will know what is required. Ill try to find out more about this, I wouldnt mind knowing how to go about it myself.
