Upgrading headunit
Discussion in 'ZB Holden Commodore (2018)' started by Villa_23, Oct 29, 2019.
  1. Villa_23
    Villa_23 New Member
    ZB RS 2.0 turbo
    Would anyone have an idea if it would be possible to upgrade the headunit in an RS to one out of a Calais.
    Thanks
  2. MattSAU2XR8
    MattSAU2XR8 Active Member
    Caloundra
    VE SS Auto 2007
    I imagine no-one has done this yet, hence no replies. Might not be the easiest project since:
    - Holden would charge a large amount for a Calais head unit new
    - Getting one second hand requires someone to either write off their new Calais, or want to upgrade to an even more expensive unit
    Given the stereo on there probably isn't too bad some other options could be:
    - Play music from your phone, either by Bluetooth, or just a USB cable to connect phone to car, I do this for Podcasts
    - Possibly some better quality speakers if you can be bothered? The digital amplifier (?) and wiring should be capable of playing music OK I think...
  3. Villa_23
    Villa_23 New Member
    ZB RS 2.0 turbo
    I’ve found a wrecked Calais and can get the headunit at a fairly reasonable price.
    There are limitations of the RS headunit that really annoy me plus I’d like to have DAB too.
  4. arsevee
    arsevee Active Member
    RS-V Sportwagon
    DAB's good... :)
    The only issue I can think of is that you may not have a GPS module installed, so the Nav won't work...
  5. Villa_23
    Villa_23 New Member
    ZB RS 2.0 turbo
    I don’t use gps so not a big problem. My main reasons for wanting to upgrade are dab, nicer touch screen and with the RS I can’t use any of the controls when I’m on a phone call.
  6. arsevee
    RS-V Sportwagon
    Yeah, no real loss on the Nav if you have CarPlay...
    If you do get the head unit out of the Calais, make sure you get the VIN etc. - it may need coding to the new car...
