Upgrading VE Stock Speakers - How To
Calais57
Donating Member
Blue Mountains, NSW
VE Calais V 6.0
boneart,
you have inspred me to research speakers and also replacement subs.
For interest most replacement 8" subs on the market appear like they require a larger hole below the sub. ie the new subs have a bigger "skirt" area below them. They are fatter below the surface speaker section.
Also the standard amp is made by Bosch in Malaysia according to the label. It is 2 x40w RMS.
Do you know if the standard subs (each is 2 Ohm, 50W) are wired in parallel or series?
boneart
Auckland
www.boneart.co.nz
VFII SS-V Redline
Subs
boneart,
I need to do a bit more research on the subs yet but I have heard that most free air compatible subs have a wider basket than the stocks which means bending a little of the metal around the base of the hole back a bit to get a fit.
As for the stock sub wiring, I believe each sub is on its own channel so they not wired in parallel or series to change the impedance load on the amp as you would with two speakers off one channel.
Not an expert on that and as I say more research needed.
This is the only wiring diagram I have found for the stock amp/subs so far so perhaps this will help
Calais57
Donating Member
Blue Mountains, NSW
VE Calais V 6.0
Boneart thanks for the diagram. I am sure it must give some good info. - quite seriously! Any techie type peope here that can interpret what it means for me? Sorry, I am a total novice at electronics.
catbert6
VE2 Calais Sportwagon V8 Redline
Any chance that someone has a wiring diagram (or good description) for a Calais Sportwagon (VE Series 2)? HOw would it differ from the sedan?
(edit: having now actually had a look in the back of my car (embarrassed look) I can see there are clearly no subs and therefore (if the amp is only there to drive the subs) no amp. Otherwise, I appears to pretty much as per the top post).
Troyziee
MY17 SSV-R Sportwagon
Anybody have any suggestions for the beat places to go to buy dynamate? I want to dynamat the doors when I do the speakers, though know it's expansive! Any stores recommended (Victoria) or just the Internet..?
Also the main pack is for 34 square ft I think it was, ppl know if that's enough to do all four doors?
Happydaze
Happydaze
GC
VH SLE T30
top post, great information
EraserHead
VE II SV6 - Alto Grey
Interesting diagram of the amp Boneart - seems they just use the front door speakers (left and right) as the input - pins 1&6 and 2&7. Very basic amp by the looks of it, all preset with no adjustments - obviously built to a price point!
316
Computers
VE Series II SV6
How do you get the center speaker cover off? I don't wanna break anything and the instructions seem a little vague to me?
