Jplough
Hi guys, Hoping someone can give me some advice.
I purchased a VX V6 engine and gearbox which I indend to drop into a series 1 VT.
The VX engine comes complete with the wiring loom intact that has been disconnected from the computer on the passenger side and the 3 connections on the drivers side.
I am told I must not disconnectin the wiring loom from the computer on the VT else it will loose its security settings with the engine. Therefore I should keep the original loom on the VT and disconnect all the wiring from the engine side and reconnect on the new engine else the security system will prevent the new engine from starting.
Is this correct?? I would have thought the wiring loom is just cable and doesn't have any security coding so what difference does it make if swap engines wiring loom and all.
Its a ton more work to disconnect everything from the engine side so would prefer to keep the existing wiring loom on the vx engine and simple connect to the computer and the 3 connections on the drivers side. (plu the odd 1 or 2 sensors that are not connecting to the engine and gearbox)
Can anyone please advise if this is bollocks or do I reall need to keep the existing wiring loom on the VT and disconnect everything from the engine to swap motors.
Thanks in advance.
Thanks in advance.
