Urgent Advice need on the L77
Discussion in 'VE Holden Commodore (2006 - 2013)' started by HEXEM, Sep 6, 2011.
  1. M500
    M500 New Member
    2009 VE SSV Ute
    Given the history with the job and the labor costs of changing these part, I would have thought that they would change the engine and the computer to ensure that they have eliminated the problem. It would also be much better from a customer service and PR point of view to make sure you praise their handling of the situation rather than rust the backlash of a genuinely unsatisfied customer.
    See if you can insist in a complete, stock, untouched engine to be installed with whatever it takes to make it work and retain your warranty.
  2. HEXEM
    HEXEM Member
    ACT
    VE II SV6
    Well the final word is Holden wont install a new engine without swaping the camshaft that is in the L77 with an L98 cam. They agreed to supply a new camshaft and not remove the one from my faulty L98. So I guess we'll see how it goes.
  3. HEXEM
    HEXEM Member
    ACT
    VE II SV6
    Well Holden never ceases to amaze me.
    Here is the lastest. The new L77 (bastardised 3/4) engine is in the process of being fitted to my car at the moment.
    I get word today that they (the dealer) has changed the camshaft from the L77 with a new L98 camshaft.
    Also as outlined in the Techline they have removed the L77 sump and will take the sump from my August 2009 built L98 (last of the L98's) and fit it to the what was new L77.
    There are 2 proceedures on the techline one for a 2007, 2008, 2009 VE with the L98 and then there are the 2009, 2010 VEs with an L98. If the L98 was fitted back in 07, 08 and early 09 is says to use the sump, dipstick tube and dipstick etc etc. For the later model VE (so MY9.5 owards) you on need to replace the Valley cover and crankshaft. There is no mention of the need to change the sump.
    I've told the dealer that yes my car is a 2007 VE but the engine is a L98 from the MY9.5 series which is why it only takes 7.6ltrs of oil. The earlier L98 had an 8.3ltr sump.
    This is just complete bullsh!t that Holden will replace an engine with a new 3/4 motor but pull it apart to swap bits (like sump, etc) because? who f$!kn knows. From what I can gather seeing NO ONE will give me a technical reason why it is imperative to change theses parts (such as if they don't the ass end will fall out of it). It defeats the purpose of supplying a new motor which is covered under a 2 year 50,000klm Holden warranty.
    I have reached the point with all this bullsh!t I have had to go through, that I will be publishing all my frustration on the various Motor magazine sites, Youtube and anywhere else it will get coverage. Basically warning people to be wary of the way Holden deals with Mechanical engineering faults. My recommendation would be not to buy a V8 holden ever. They have had so many years to get it right an still can't do it.
    I am also in the process of obtaining professional advice in which to take the matter further.
    NOTE: I should add though. Except for what appears to be a lack of care resulting in the sump being removed possibly unnecessarly, my local Holden dealer have been great to work with.
    Also was told today that they no longer take the motor out through the top of the engine bay. They remove the engine out the bottom. Yep got to pull all the subframe crap, steering, etc etc out to change the engine. What use to be a 2 day job now becomes a week (maybe longer)......
    Heres a pic of the so called NEW 3/4 engine minus the sump.
  4. HEXEM
    HEXEM Member
    ACT
    VE II SV6
    I received advice today that they will be refitting the sump that came with the new motor as it shouldn't have been removed.
    I'm glad the service manager is on the ball. +1 for him.
  5. SSVAGON
    SSVAGON New Member
    VEII SV6 Ute
    Golf clap.:clapping:
    Thank god for that.
  6. UFO
    UFO I Believe
    MY10 VE International Sportwagon SIDI 3L
    holy crap dude. i've sat here reading all of your posts and i've just realised my mouth was wide open in disbelief the whole time.
    i dont know what i'd do if my brand new car needed all this work done.... i feel for you mate, really.
    keep us updated, this is a very interesting read!
  7. Dr HaxZaw
    Dr HaxZaw New Member
    R34 GT-T
    and i thought i had issues with a second hand ecotec...
  8. Thumpin
    Thumpin Member
    top of Sydney basin
    VE II SSV Sportwagon
    Shame they had to break the virgin seal...
  9. Drewie
    Drewie Active Member
    East of Melbourne
    VX SS (Original owner).
    I have been thinking of updating my VX SS to a VE SS, I can't believe after 12 years GM are still having issues with these LS motors, I went through all this back in 2001, after reading this thread and a few others I might go for an SV6 or Calais with the SIDI 6 cylinder, not overly confident on the 8's, seems a bit of a lucky dip.
  10. shadetreemechanic
    shadetreemechanic Member
    perth
    VR v6
    Yeah i gotta admit reading this thread is really interesting. The one thing that gets me though is how the OP went through *three* motors in 2 years..that's nuts...
    Wondering if there's something in it? (not blaming the op but that's gotta be some coincidence)
    What happened with the other 2 motors? Same fault?
  11. HEXEM
    HEXEM Member
    ACT
    VE II SV6
    The original engine developed the same problem at about 30,000klm. It took another 30,000klm before anyone would admit that there was a problem. At the time there were no L98 engine available so they had to go with Option 1 of the Techline which is to use a cylinder block and rebuild it using parts from the OEM engine. Within a few months the same noise came back. To rule out a build quality issue they were able to source a 3/4 crate motor. This was installed last November after a lengthly battle again for them to recognise it was the same issue and they wanted it to get much worse than it was before doing anything.
    Around march or so the new engine had completed about 8,000klm and I was called in for an oil change. They used a 10w30 semi syn and with a few weeks I started noticing the noise in the mornings. Then the fight started all over again.
    The car is not driven hard, modified in anyway. I cant speak for anyone who has driven it at the dealership when servicing. It is primarily a family car and I always have the kids in it. I guess I have been unlucky. My issue is not so much the product but how its handeled by Holden to get thing resloved, and I'm not talking about my dealer. They have been good. Its the people that represent Holden's view of these situations.
    Anyway you can only take my word for it but those who have seen how I look after my cars no its not a driver related issue. If the info I put up helps others then I've achieved something.
  12. petergl67
    petergl67 New Member
    delahey
    holden commodore super 6
    Hexem
    Interesting topic. Sorry for u just had bad luck. Reading this post I dot think I would buy a Ls still all the issues and Holden are just wasting everyones time
  13. Advanced_Amatuer
    Advanced_Amatuer New Member
    VE SS 2010
    I can understand Hexems desire not to purchase another holden V8.
    I previously had a turbocharged vehicle and after the turbo needing replacing (under warranty) at 30,000 km it put me off from buying a turbo vehicle again.
    Hence my decision to go NA and not TC. I had ppl ask why i didnt consider an xr6 turbo and quickly explained why it wasnt an option (Not to mention Im not a fan of ford).
    You see, it depends on your experiences. I read all of hexems posts and although it made me think twice about a v8, i certainly wasnt getting a turbo family car, no matter
    how many assurances i got about how reliable they are. NO TURBO.
    Just bad luck mate, but what can anyone say, trust holden, its a good car, etc etc.
    I had a jeep patriot with the 2.0 turbo diesel, the Vw unit.
    And the turbo **** itself. pffffffft. Got it replaced, and sold it (not to mention the same symptoms occured soon thereafter)
    (and before anyone posts anything about turbos, how did you break it in, drive it etc etc trust me, it was a problem with the vw's)
  14. HEXEM
    HEXEM Member
    ACT
    VE II SV6
    Hi all,
    I thought I'd update everyone on the latest with my 'NEW' engine being fitted.
    Just got off the phone with the Holden dealer. They said I won't be getting my car back today as there is a problem with the new motor. It is rattling its head off up the top end somewhere and they don't know why (like I said why change the camshaft?) anyway we'll let that one go. They told me that they will need to contact Holden TAC (yaaay!!!) for advice.
    Here we go again. I'm placing bets that they want to pull the heads off etc etc etc..... F%$K when will it ever end!?
  15. bluessv
    bluessv New Member
    Moree
    VE Commodore SS Thunder Ute
    Oh Holden, can I please also have brand new replacement engine under warranty. But before you put it in can you pull apart a perfectly good engine to install a camshaft that was never designed for that motor (without changing pushrod lengths to accommodate the different cam specs)...and can you also pull the heads off and #### all the seals and lifters...pretty please!!!
    Holden you should hang your head in shame. If I owned a performance shop and a Holden tech engineer wanted a job based on his qualifications I'd send him to the closest Centrelink!! Pathetic
  16. HEXEM
    HEXEM Member
    ACT
    VE II SV6
    Well it just keeps getting better.
    Phoned the service department today to see what's happening with my car. Was told that the service manager will ring be back (I think I should have stipulated a date and time) the afternoon goes by so I SMS the manager and they reply to my SMS instead of calling me. I suppose I should be lucky I got the SMS.
    Anyway, the message tells me that they (the dealer) has stripped the motor (this is the Brand NEW L77) down (heads off, lifters out, etc etc.) to find the fault. Got the usual response of cause 'Nothing Found'. So they are putting it back together and will see how it sounds...
    I must have crossed the path of a lot of black cats in my day to deserve this crap... I think it might be time to take this issue to the Department of Fair Trading or Consumer Affairs.
  17. Reaper
    I'm quite surprised all the dramas this guy has had. The 2 of these motors I had were fine from go to woah. Same goes with the E3 thus far. I must be lucky though - never had a problem with any of the GenIII motors I had either.
    Reaper
  18. HEXEM
    HEXEM Member
    ACT
    VE II SV6
  19. andyman
    andyman The Only 6sp VZ Wagon
    Orange, NSW
    2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
    that really suck with what youve had to go through, but actually dropping the engine out via the subframe is not bad form at all.
    all you have to do is unbolt the steeringshaft to the rack, strut tops, unbolt the tail shaft, rear crossmember, disconnect fuel lines, a/c coolent wiring etc, unbolt the k-frame and lift the body away with a 2 post hoist,
    save removing the bonnett, the plenum cover, wipers and trim from top of the engine bay and potentially creating many marks, chips and scratches
  20. Thumpin
    Thumpin Member
    top of Sydney basin
    Pretty basic tech bulletin. No rocket science there. Where does it mention the L77?
    I wonder if all your L98 valve train components were match-marked and refitted into their original order (meaning they change the cam, lifters & pushrods from the L98) into the new block. I'm thinking NOT.
    Sounds like a comedy of errors by the uneducated!!
    I think they should jack-up the compliance plate and roll a new car underneath or accidently burn it to a shell and cut their losses...
    Its not fair to sell a product and then to practice trying to make it right when the buyer (public) is disadvantaged by the actions. We need to learn alot about automotive customer service in this fine land.:spew:
