URGENT!!! Door Won't Open??
acarmody
Donati..Whoa Green
VX Berlina
IF FIXED IT, I FIXED IT!! LA DI DA DI DAAAA!!! basically I took the door handle off, pulled all the lock casing off etc, put everything back together, got mad slammed the door a few times and now it works fine!!! ^_^
If only smashing stuff worked on everything, life would be so much better.
lout
60
Langwarrin Victoria
I would leave your door trim off until you fix it properly
pirateandy
61
brisbane
S2 VY executive
HOW TO DO IT...Just had this happen this morning. I put the car in to have central locking fixed and not only is the central locking still stuffed but they didnt put the rod on to unlock the door from outside. I decided to do the rod and deadlocked the door. I had the interior trim off which made this easier. Ok here goes.
You need to get the exterior door handle out. If your interior trim is still on you may need to cut it down towards where the lock is to get to the 2 10mm nuts holding the handle on. Remove the handle and inside you'll see a blue cover over the locking mechanism. It just pulls out. You'll see a bracket in there that has about 4 tabs, this is the lock, get a screw driver and rotate this, it wont need force, you'll see it rotate and the door will open. Once the door is open pull the lock out and play with the same piece you rotated. It'll go into position that it should be. Use the screwdriver to activate the lock the check it unlocks ok. Reassemble.
Hope this helps
Hope this helps.
pirateandy
61
brisbane
S2 VY executive
Update. After 20 attempts the door kept deadlocking. I finally worked out that the rod on the outside handle has an adjustment. Turn the nylon nut anti clockwise a few turns and the problem is solved. Good luck
steve horsburgh
58
Kinglake
By commodore
Hi it appears I have the same or similar issue, VT driver door can’t open it, just wondering how you got it open
NussSuss
Loganlea
Holden VE Series 2 omega
I need help guys!!
I changed a mirror in my ve series 2 - all good - until I realised my passenger door won’t open!!
Ve series 2 don’t have key locks… can anyone help?? I can’t even get the trim off because it’s closed! :(
lout
60
Langwarrin Victoria
more details please
is it locked, dead locked or unlocked but wont open
have you tried inside and outside handle
most likely rod has come off at inner door open handle
go fishing and see if you can hook rod
NussSuss
Loganlea
more details please
It won’t open inside or outside
