URGENT-VX door panel removal
Ronno
Western Australia
VX Wagon
Hi, could some one tell me how to remove the front door panel, I have removed the obvious screws, inside handle and lock- but something appears to be holding it near the top, does the small trim panel need to be removed -if so how? Regards ronno
hakhawk
smooth moderator
Staff member
did you remove the handle and undo the screw behind it? i almost always forget that one.
DavesCalais
VT Calais
Snippernob is the door lock should be a small red tap that you can pull out ward and release the lock
Sent from my XT910 using Tapatalk 2
Nut Kracker
Donating Member
62
Echuca Vic.
VT SS 304ci (195i)
Yep.....and there is a screw behind it.
hakhawk
smooth moderator
Staff member
and assuming the op means "lock" when he says "lock", its already been removed.
op, you will also need to lift the trim upwards as you remove it, as it slots into the door frame along the window edge
