using different wedge fuses
Discussion in 'General' started by greenvs, Apr 24, 2007.
  1. greenvs
    greenvs New Member
    Northern Suburbs
    VS Caprice SII
    is it okay to use a different rating wedge fuse than what is specified on the car
  2. calais_cruzin
    calais_cruzin Calais_Rattling....
    Gold Coast
    92 VP Calais 3.8
    It depends, i would use say a 30amp instead of a 25amp if i had no 25amps, but no way would u put a 30amp inplace of say a 5amp fuse.
    Im not sure but i wouldnt let much more amps thru then what is specified.
    I used to blow my cooling system fuse, it was a 15amp i think by my dodgy memory, i just kept stepping up a rating until it stopped blowin, but that was coz i was too tight to go to the auto elec n get a new relay for it. 30amp stoped it blowin.
    Sumone else will definatly know, but i wouldnt go puttin too big of fuse in there.
  3. vy_storm
    vy_storm just another moderator... Staff Member
    the burbs of Adelaide
    VE Calais V 6L
    Generally no. The rating specified is there for a reason, normally to protect what is operating on the circuits in question. Ie, If you keep blowing fuses, putting a higher amperage one in there is only masking the real problem.
  4. greenvs
    greenvs New Member
    Northern Suburbs
    VS Caprice SII
    thanks guys for ur help
  5. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    Worse case you can burn your car to the ground by fitting a higher rated fuse than what is specified. The current draw is what blows the fuse because it is too high, if you match a fuse to the current then whatever is drawing that current is getting too hot and can set fire to surrounding items if they are combustible.
