Ute Rear Suspension
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by pottsy, Jul 20, 2006.
  1. pottsy
    pottsy Guest
    Hi guys I happened on your site tonight.
    I own a VR Ute. Tonight while tinkering in my shed I found on the right side behind the rear wheel arch a (tire type) valve that leads to my shocks is this stock? I pushed it in and no air came out. My back end is (a little) higher than my front but I think that is normal? Front doesn’t look lowered… What would happen if I pumped some air in there? Sorry for the complete ignorance as I’m only 18 and have herein spent most of my mechanical time on my motorbikes.
    cheers
    Gus
  2. Patrio7
    Patrio7 3Y3 K4N 5P33K 1337.
    Perth, Como
    '96 S1 VS Exec
    its air bag shocks, basicly if you wanna haul something big then you can inflate that thing to stop your suspension from bottoming out, once you unload, you drain it out and its normal.
    basicly you would pump up your shocks under pressure to make the car act normal under weight.
  3. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    You can try putting air in the shocks but they are likely to leak down due to past stone damage to the rubber air bags and/or the flexible nylon air tubing....but you've got nothing to lose. Some people also used them for towing a caravan or nose-heavy trailer but they seem to have lost popularity in the last few years.
  4. TOBSTA
    TOBSTA Guest
    pump it up
    put 50 psi in and see wat happens go on i would
