Ute rear window panel removel
birdwiser84
VY II Ute
Hi
So basically the clear coat has peeled off on the plastic panels around the back window of my Ute, I've got a full spray setup so i'm going to fix them up myself but I cant work out how to get the bloody things off and my workshop manual doesn't have the info either, feels like it should just pop but don't want to force and break it. Any suggestions??
(pic of another ute which had the panel in question pointed already, how handy)
Jaydenvz
White knuckle fever
Gold Coast
Vz excecutive ute
Hey mate I have had the same problem with mine I just purchased a new sailplane with the lights in it off a SS when I head home tonight I will take some pics of what the inside of the panel looks like for you so you can see it does just pop out but there are 4-6 points that it connects too I think the aid of a electrical flat head screwdriver helps, I find the electrical ones are a little more forgiving on the paint work as they are plastic coated
sp001in
vyma100
41
QLD
VY ute
Gee I look after you boys.
mdzWA
WA
VY Storm 2004
gooday, many thanks for the instructions and the picture is perfect to explain it all.
do you have further instructions or tips to take off all the other plastic bits that clear cote has peeled.
can you post pictures of the rear window side plastic panel removal please?
Ned Kelly
39
Queensland
VZ Tonner
Just doing the same myself, did you find out how and if so, can you post please?
mdzWA
WA
VY Storm 2004
hi ned, sorry havnt found out yet, so job not done. ive been busy with changing clutch an brake linings
and will do paint job later after i figure out how to take off the plastic bits.
if you find any instruction diagrams, please post a reply. thanks, michael.
Ned Kelly
39
Queensland
VZ Tonner
Found it, you need to remove the glass as there are screws under the seals...
