V.I.N Number
Super Coach
GTS, S, CV8Z, SSVR
GTS, S PAK, CV8Z, SSVR, CALAIS V, MSE
Does anybody know how to determine what number your vehicle is off the production line? E.g. Car number 450,451,452 by reading the V.I.N or does this not tell you.
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
This is what it says
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
Hmmm....didn't work for me although on my 4th attempt it blocked me out saying I had 3 goes and I must be a commercial user. Only thing I may have done wrong was to have "caps Lock" on. The 4th time I tried using the "shift" key!!!
Will try again in 24 hours.
Super Coach
GTS, S, CV8Z, SSVR
DeiCide that link works but it says my VIN ain't valid. Just looking at the sheet sent by markovr the serial sequence number how do you determine the build number from that. Cos I went and had a look at the ID plate in the engine bay it comes up with two numbers the model number and the body number and Im sure my car aunt the 883618 down the line. I know with the newer cars they have stickers on the front window drivers side e.g. VE 0015 my grandads VN had one so we know his is the 1015 car down the line
Patrio7
3Y3 K4N 5P33K 1337.
Perth, Como
'96 S1 VS Exec
"And continues in sequence regardless of the model" ( according to the linked above pic )
lets seem my vin is 6H8VSK19HTL919764
ok lets break it down
6H8 - Holden ( of course )
VS ( i knew that >.< 0
K - Exec ( yay for entry level )
19 - Sedan
H - 6cyl
T - ( year code ....mines a 96?)
L - ( oh noes my car was born in SA! )
919764 - ( Serial, my dads 95 acclaim is 818xxx )
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
So has anyone got the link to work because I just went back in and it says it doesn't recognise my WMI?
Its 6H8VSK19HVL210851
Maybe my car doesn't exist.
DeiCide
DeiCide
VT S2 L67
ah sorry, Didn't check it out before...
Turns out its for Foreign cars VIN no's.
But that sheet markovr posted is spot on
JD
Donating Member
37
Deep South, SA
www.ccgm.au.tt
1.6L Turbo Holden Croooooooooooze
its easy 4 my car it says build no. on the hsv compliance plate:yeah:
