Rod Hirst
- Jan 23, 2018
- 14
- 0
- 1
- Age
- 67
- Location
- New Zealand
- VT Commodore Acclaim 3.8
Ive had an issue with the srs light coming on beeping three times ,stays on for a while after three or so kms goes out,but reappears once car is turned off.I have heard that the terminal conectors leading to the pretensioners (green with metal clips) and some of the other conectors beside seat can bring up an error if they have moisture or corrosion on any of there contacts. I removed both battery terminals ,left for a day or two removed seats,inspected terminal conectors,one leadind to side airbag was corroded ,cleaned that, used conductive carbon grease to lube contacts,checked all leads etc no problems anywhere.Purchased SRS diagnostic scanning software but Software wont connect up to car. my question is,if the ABS computer module is faulty,(only the srs light is staying on) will it prevent me from connecting up to car to diagnose??
