V2 immobiliser switch
VZ AlloyTech
VZ AlloyTech Rodeo
hi I read that inside the passenger side door there is a switch that allows you to turn off the immobiliser, I think they said you use zadi key, does the VZ have one
Thanks
krusing
Melbourne, Bayside
The only way is disable the immobilizer is with a Tech2.
Big Red VF-SII Go-kart
I love puddles.
Darwin NT
VFII MY17 SV6 (LFX) Sportwagon (SOLD)
What the hell are you doing trying to disable the immobiliser!? Really. If you you are really keen to do that and want somebody to come along and nick the car in short time, free of hindrance and hassle, just leave it at the adventure playground.
And no, none of the VZ cars have any such switch to null the immobiliser. There are other hidden, loomed switches (4) that do specific things depending on options such as those used by Services cars. In the absence of such options, they are null and void.
The immobiliser lamp on the dashboard is programmable in its behaviour (by Holden). There is no real reason for this light to be changed.
Fu Manchu
WA.
Thanks
That was the VP.
Trevor loves holden.
vs commodore
My VR had a key to turn it off in the front passenger side door jamb. Why do you need to disarm it.
I love puddles.
Darwin NT
That was the VP.
Yes this also appeared in the quirky Toyota Lexcen/Holden VP Commodore-cross from 1992 to 1997. I had one of these Lexcen wagons (1992 to 2010 - a disastrously mismatched experiment between Holden and Toyota! ) and the immobiliser frequently had to be turned off (dedicated key) at the front passenger side panel because of a battery fault. But this switch was not carried over to the VZ, in which sub-category thread appears.
_R_J_K_
Zenki S14
It was before the immobilizer function was integrated into the BCM and key head and it was far less reliable/integrated so you could just turn it off completely if you were having issues instead of being stuck at the supermarket or whatever. Incidentally it was super common for the immobilizer switch itself to fail and cause big issues too.
