gohrdrgomad
- Dec 16, 2016
- 465
- 65
- 28
- Location
- Australia
- VxCaly57
Forgot to mention anything infront of the radiater blocked with roadkill. Also as the trans cooler is sometimes fitted infront of the a/c condenser and that is infront of the radiater this reduces the cooling, so inshort the hot trans cooler is a big issue....If the alloy fins are choked up with roadkill bugs n g-hoppers or bent/dinted the cooling ability reducess. You can spend some time picking them out with some tweezers then give the area a hose out. Give it a flush with a cleaner and fill with new coolant ( penrite consitrate) dilute at 50% for maximum cooling and freezing properties. Even check the thermostat is opening fully.
