Sammy
- May 6, 2004
- 387
- 7
- 0
- Age
- 44
- Location
- Tenambit, NSW.
- Website
- www.oldholdens.com
- LH Torana with Ecotec V6
they would have to have made atleast some increase in performance
Sammy said:i use the inlet/exhaust gaskets to work out how far to take the ports out to, as for the valve area its really guess work for me if they all look the same i'm happy.Sammy said:I've heard that minimal metal removal is the way to go, if you enlarge the runners to much and increase the runner volume you loose the intake charge velocity and this is bad for making power unless your making a high revving circle track racing engine. cleanup the bowl area and around the valve guide too but leave a little more metal around the exhaust valve guide to help dissapate the heat in the valve stem, even better, get some bronze valve guides fitted while your at it as after 300,000km their gotta be some wear and tear there and a 3 angle valve grind
