V6 Holden Mini ecotech wiring?
Mad Geordie
75
New Zealand
calais
I have grafted a 3.8 V6 into a Mini as you do and Im about to try and wire it. I don't have the key. how do I by pass it? Can I cut out al the ABS part of the harness, Can I cut out all the Air Bag stuff, Can I cut out all the power door stuff? Is ther a simple version of the harness out there? its an auto I have the whole harness. Is ther a simple electric pump theat the computer will recongnise to save grafiting the Commodore pump into my new tank?
wamboin23
Donating Member w/ Boost
34
Wamboin, NSW
VS Calais - Cooled L67 + T56 | VF SSV Ute
need to get the security turned off in the memcal. speak to delcowizzid, who is also in nz...
you should only need the engine harness, the ABS, SRS etc, are all part of the body harness.
any electric fuel pump will work, as long as it flows enough fuel.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
the whole engine harness is seperate from the rest of the car its easy to wire up to run in anything yell out if you need a hand
