V6 Intermittent miss
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by VR38, Feb 27, 2009.
  1. VR38
    VR38 Well-Known Member
    VB SL/E
    My VR V6 has an intermittent miss on cylinders 4 and 6, checked with the timing light all other cylinders constantly flash including the opposite cylinder on the two coils in question.
    Leads and plugs check out o.k. so I am am guessing it is the ignition module right?
  2. hako
    hako Donating Member
    Toowoomba SE QLD
    VS11 BT1 V6
    Not sure how you've tested the leads/plugs but maybe try and replace those 2 first....one thing I've done to remove a miss is to gap the offending plug down to 1.0mm which make it easier to fire. Maybe also look at the engine running after dark to see if there is any high voltage leakage. Good Luck.
