Dozer31
- Sep 5, 2021
- 168
- 47
- 28
- Age
- 53
- Location
- Ringwood North
- 2007 VE S1 calais
Hi All
I have a leo Ly7 motor with some engine noise which I just cannot figure out where it is coming from.
So, I replaced timing chains with gears, oil pump, tensioners, and mace performance cam and
Installed inlet spacer.
Since these works motor is quite when cold but is noisy on idle when sightly warmed up. It's a bit of a knocking noise but tends to quite down when you accelerate.
Background of motor, high km,s was throughing fault code, changed chains, gears and cams. motor full of sludge cleaned inside front of motor at rear of chains and inside of rocker assembly.
When cams installed lash lifers taken out to inspect along with rocker arms and put back where they come from.
Turned motor over my hand to ensure seated rite.
Prior to this motor ran quite.
Any ideas what might be the cause.
Thanks
Thanks
