V6 not starting
Jacko84
Girrawheen
VS Berlina soon to be 5L
hi all my beloved vs commodore is not starting, it cranks over but doesnt fire, checked codes none come up, snap on scanner, i've got spark, but dont have clip to get fuel pressure line off at home its at work get it tommorow, but the security coded led goes off when i turn ignition on but starts flashing when i crank it over.
so is it a bcm issue or a farked fuel pump.( cant here pump priming when iginition turned on)
whacked the bottom of the fuel tank does nothing
Brett_jjj
Tamworth NSW
vs commodore
If you cant hear the fuel pump prime for the 2 seconds,then thats probably whats wrong with it.You can try to get it running by getting someone to belt the bottom of the fuel tank with a piece of wood whilst you turn the ignition key to the on position.Sometimes its just enough of a jolt to get it running again.
Krisp
35
perth
D22 St-r Navara
sounds like battery in your key head not turning off the imobiliser
Brett_jjj
Tamworth NSW
vs commodore
Usually if its a problem with the ignition keyfob, or if the immobiliser(BCM) doesnt recieve a signal from the keyfob for some reason,the engine wont even attempt to crank over.Try pressing the remote buttons while cranking it and see what happens.
GothicKidd
ლ(ಠ益ಠლ
South Australia
VR S2 Exec
Could be a fuse? Check your engine fuse in ur engine bay.. I couldnt start my car, and fuel pump wasnt priming.. and it was just a fuse..
Jacko84
Girrawheen
Fuel pump, all fixed now
Z2TT
VL Commodore
Hi,
I've got a similar problem i got a VS.
The car starts, but needs cranking of probably 3 seconds, I don't think I can hear the fuel pump priming,
but it definitely runs once car is on as it doesn't stall or anything.
Just wondering how loud should the fuel pump be, do you have to be right near the tank to hear it?
Jacko84
Girrawheen
what state u in easy as test take the fuel line off at rear of engine bay drivers side turn key onto ignition should have fuel priming out .
