V6 oil pump help
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by immortality, Apr 22, 2008.
  1. immortality
    Sth Auck, NZ
    are there any differences between the s1 and s2 onwards buick oil pumps other then the stronger bypass spring on the s2 that increases max oil pressure from 50psi (s1) to 60psi (s2 onwards).
    i want to make sure i've got heaps of oil pressure before i subject it to a shot of nitrous. i'll be fitting a new timing chain most likely to ensure accurate cam timing and will obviously have the cover of so can do the oil pump at the same time if required
    cheers
  2. PaRaDoX
    PaRaDoX Because Racecouch...
    Melbourne, Victoria
    none
    im not sure on this but why not fit a oil pressure gauge...????
  3. immortality
    Sth Auck, NZ
    i have and it's as it should be (for a s1 engine) but i want more oil pressure as cheap insurance and my gregories says the s2 engines have more oil presure
    s1 max pressure 50psi
    minimum pressure 40psi @ 1850rpm (operating temp)
    pressure relief spring = 64.8mm
    s2 max pressure 60psi
    minimum pressure 55psi@ 1850rpm (operating temp)
    pressure releif spring = 66.3mm
    so the relief spring is definitly longer resulting in the increase in max pressure, however the s2 minimum pressure is 15psi more at the same RPM and that wouldn't be related to the presure relief spring. i'm guessing that there must be some sort of difference between the 2 pumps? just wondering if anybody knows?
  4. commsirac
    commsirac Banned
    vx
    My guess would be that the driven gears are different on the higher pressure unit, to create higher pressure the volume that the pump moves out has to be higher.
    Other alternative would be its for a different viscosity oil, but probably not.
    One concern is that I would never put my house on anything written in the Gregory's manuals........they have been wrong before(dangerously wrong)...........
  5. immortality
    Sth Auck, NZ
    there is that. also consulting a haynes manaul including VS
    all except 1991 VN series 275kpa (40psi) warm
    1991 VN series 375kpa (55psi) warm
    however i can't find any mention of the max pressure for either or what the pressure releif spring lenght should be????
    i guess maybe fitting a presure releif spring for a 1991 VN and see what it does is the easiest option. i am certain that the later model does have the increased max pressure however if you read it as per the haynes it suggests that the later models (V6 upto 1998 covered by the same manual) actaully run the lower pressure again???? odd
  6. jas98
    jas98 Active Member
    maryborough QLD
    vs commodore V6 S2 and a BA XR6T
    im pretty sure that the springs are interchangeable..like most places will just sell ya the series 2 spring anyway..as far as i know and herd the spring was mad bigger to make the pressure higher and are interchangeable with series 1....the timeing cover is not however as it has different coolent passagees or something
  7. immortality
    Sth Auck, NZ
    yeah, i'll probably just fit a s2 spring and see what it does
