Yep I agree, this place is awesome for help. So many people with knowledge getting us out of strife! ...and into it too sometimes lol
Depending, definitely worth replacing everything back there for peace of mind. Don't wanna have to pull the tranny back out.
What stage are you up to now? Do you only need the guides or did you take the kit back? I can confirm that the Holden kits come with the plastic guides. Pretty sure they import the whole kit complete. I was (and still am) such a noob - in the Holden kit, I thought the rear main seal they had pre inserted in the cover was white plastic. I was devastated. Was just about to put the rear cover on and the white plastic thing popped out. I freaked. Then I realised that the white plastic was just to protect the actual rear main seal
Sucks getting that far into it and not having what's required. Having a purchased item not come with everything required is a real hassle. You expect it to be in there and you feel cheated really. I once bought some plenum bolts from a Holden dealer and they all came in separate paper packs. Got to the car and started to count them and noticed that about 4 of the packs had already been opened and there were no bolts inside. Some wally had opened them obviously, taken them out and thrown the empty packs back onto the stock shelf. I went back in and told them but the chap thought I had flogged them. I think more than anything he was embarrassed about what happened, couldn't accept responsibility and wanted to blame me for it. Over a year later and every time I go back there, I ask them if they have gotten the replacement bolts in yet. Needless to say they never have.
I originally used the old bolts but I guess because they had already pre-stretched, when I did them up to torque and then angle, I might have fractionally over tightened them because of them already being stretched. I think that's how it works? Should have done them up a touch looser but I was none the wiser back then (still am). Makes it hard with supposed tty bolts that's why when I used the new bolts, it was perfect. Honestly I thought they were fine and still do. But I'd rather at that point just to replace everything than go through that again.
Possibility too that the rear plate was warped but the machining shop said it was fine to reuse. They even gave it a once over for me. Worst bit was the Permaseal rear cover gasket pre-glued sealant strip (which I never noticed until after removal) wasn't straight and actually wasn't just off centre but ran off the gasket. Definitely put some sealant on for peace of mind. Needless to say that the Permaseal phone call ended up with them never ringing me back as they promised and fobbed me off coz I wanted them to wear the cost of the rear cover kit, oil, coolant and oil filter. More than happy to name them too because they don't even know what gaskets come in their kits. They just copy other gaskets and o-rings and their gasket quality and quality control is crap.
