V6 Turbo Anyone?
C
Comcrazy
Guest
Hi All, I have been toying with the idea of fitting a Turbo to my V6 Vt Commodore for some time now and have finally decided to to somthing about it. I have heard that they have loads of potential and was wondering if anyone had any info on the subject. Really want to see this happen and have been putting the pennies aside. Just love the idea of being able to drive your car around as a sleeper and having the grunt there when it counts. Any input would be apreciated.
Comcrazy
Torana
Young Einstein
34
Meadowbank, Sydney, NSW
holdenworld.tt.cx
KE Laser Ghia 1.6 Carbie M5
Damn you! I thought you meant Holden was going to release a Turbo Alloytec (please Holden, please Holden!!!). Sorry but I don't know much about this stuff but I do know that it would be really good once finished. Good Luck and be careful of the cops...
D
death-from-above
Guest
There are a few different options and companies that have bolt on turbo and supercharger kits.
Check out:
http://www.capa.com.au/kits_holden.htm
http://www.v6supercharged.com.au/turbo_manifold.asp
http://www.rodshop.com.au/superchargerholdv6.htm
http://www.cardomain.com/memberpage/649207/3
Not sure if im allowed to say this (although i know most members are a member of both) but check out streetcommodres forum, theres heaps of info on turbo'ing a V6 ecotec. You will be looking around the 7k mark to turbo your car. So i hope your saving has been quite good.
D
death-from-above
Guest
By the way, this should be in the V6 section not the straight 6 section.
C
Comcrazy
Guest
comcrazy
Ur right!! This should be in the V6 Section not the straight 6, but this is the first time I have used this forum so you will have to excuse me!! Thanks for the info.Will check out the links I have been saving my pennies around 15k now, but heard down the grapevine that there are or will be soon bolt on kits available that could get you a result of around the 300hp. Not too bad I thought if this is true from a humble V6. This is supposed to include the modified memcal too. In the meantime will keep reaseaching!!.
Comcrazy.
D
DRF74
Guest
hey mate i been resarching this for a while now if you have an L67 bottom end like tony (tonsta guy with the tuffest v6 in the country atm producing 440.6rwhp on a stock l67 bottom end stock heads his mods are F.I.T 1.9:1 roller rockers F.I.T turbo manfiolds and intercooler and a dump back exhaust... and his tuned memcal .... so yeah u can but the l32 (n/a version) wont hold up look on the sc forums and see turbo ecotecs post hes gone thru 3 engines soo far... they just let got if u rebuild them yeha sure they are good but why spend soo much n a rebuild whe u can get a 67 bottom end frm holden for $2200
dwilz
66
VS 3.8 c4
Ive got a twin turbo set up its been running for just over a year,has done about 70+ dyno runs about 80 odd runs down the track runs at 11.36s@118mph and its an ecotec so far so good.
D
DRF74
Guest
yeah but david yours is fuckin TUFF as .. not stock bottom end ... i love your car btw...... hmm i want
dwilz
66
VS 3.8 c4
i recon a stock supercharged bottom end could handle a fair bit of power just give it a nice cam good set of heads a couple of not over rated turbos cool air
and it will scream, and a must get the timing rite or bang :)
