V6 VE engine into 2006 Rodeo
Gmdrodeo2019
74
2006 V6 Rodeo
Can anyone help with info of installing VE V6 into 2006 Rodeo. I have read in other thread that there are ECU problems.
Gmdrodeo2019
74
2006 V6 Rodeo
Thanks for the reply, will purchase complete car at auction to will have ecu and wiring loom.
xauterus
Brisvagas
Yes
Normally on a gm you have the vats removed so that it doesnt need the bcm. Guys who do the ls ecus might be able to do the alloytec ecu.
Gmdrodeo2019
74
2006 V6 Rodeo
Sorry need some help with the lingo, what is have the vats removed, bcm, ls ecu
xauterus
Brisvagas
Yes
Vehicle anti theft system. Its the security system. Body control module sees key and tells the ecu its fine to allow engine to start. So you want that removed. Then you run engine on seperate harness to the body.
