v6 vp berlina help needed
sparksy07
canberra
VT Calais 5.0ltr
hi all ,
need help!! Put new extractors on v6 vp after headder cracked now wont run properly ?
back fires coughs and splutters when under load feels like it wants to go but just cant revs and no go?
idles great and free revs fine.
checked sparks & plugs leads extractor bolts all good
any ideas ?
ucwepn
America just kicked in yo
www.darkcold.com
WH statesman 5.7
oxygen sensor?
sparksy07
canberra
VT Calais 5.0ltr
thanks i will try that i will get a new one !
Brett_jjj
Tamworth NSW
vs commodore
The oxygen sensor wont cause it to run crook and misfire etc,even if its not working at all.Were the plug leads removed when you did the manifold.Id check to make sure they are on the right cylinder numbers.If they are silicon type plug leads,they can be easily broken if pulled too hard whilst removing them from the plugs or getting them kinked tightly,when I say broken,I mean it can break the carbon core inside the lead which makes the lead useless under load,it will just cause a misfire under load or power.It really doesnt take much force to break the carbon core, especially if they are a bit old.Ive done it a couple of times over the years..
KiwiHoldenDriver
Loud, proud Kiwi
Auckland, New Zealand
VT Olympic Spec V6, Suzuki Boulevard S40
Agreed. This occurred with an old Toymota my mum used to own. Idled fine but as soon as a load was put on it, it misfired until the it was no longer accelerating then the misfire disappeared. Swapped out the leads and it ran as well as could be expected. Also check that the spark plug leads are firmly seated as there may be enough contact for idle operations but not for loaded operation.
sparksy07
canberra
VT Calais 5.0ltr
replaced the leads . but still back firing under load ?
could it be one of the coil packs?
Super_Low 91
┌∩┐(◕_◕)┌∩┐
Aussie
Not a Commodore
leads on in the correct order,, kinda of an obvious thing but is something that i have done before when i was in a rush..
