V6 VT Coolant in random places
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by teflondon, Feb 4, 2011.
  1. teflondon
    teflondon New Member
    VT executive
    Hi all, im new to the site and this is my first post so please bear with me.
    I have been having issues with coolant loss as of late (suspected blown head gasket) which i have put chemi weld through the radiator to give me a bit more time (saving for a new engine mine has 380 tho on the clock and is very tired).
    The chemi weld stopped the fluid loss so i thought i would flush the rad and put new coolant in it. I checked the fluid today and it has gone down again but low and behold i looked at the power streeing fluid resoviour and there appears to be green coolant in it, I sure as hell didnt put it there, just wondering if anyone out there has seen this before????? as i didnt realise it was even possible.
    Any help would be greatfuly accepted.
  2. 2DIE
    2DIE ONEDOLLAHOLLA
    South Aus
    97 Acclaim
    Head gaskets arent very hard to replace, if you buy some gaskets and have a torque wrench you could do it in a couple of hours alone.
    Not sure how you would get coolant on the power steering resoviour unless its squirting there under pressure from somewhere else. (just re-read it) There is no way coolant can get inside it as far as I know.
