V8 Cluster into V6 VS
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by cypher967, Sep 19, 2006.
  1. cypher967
    cypher967 HSV VT 5.0 195i
    VS Commodore S
    Can the V8 clusters fit into V6 commodores? or does there need to be some wiring changes? cheers Ben
  2. Boonz
    Boonz Donating Member
    berri, south australia
    green 355 VG ute
    the tacho will be reading out, i think the speed sender uses the same pulse width in 6's and 8's but just put in the V6 one its alot easier...
  3. cypher967
    VS Commodore S
    I bought an HSV 250km Speedo and trip computer and looms which cost a f****** mint. I have tried the cluster and only the Speedo and Fuel is working not temp or Revs so im guessing that the cluster needs to be changed to suit anyone know where to get this done? cheers
  4. Fekason
    Fekason Fekason
    Penrith NSW
    Cluster problem.
    The temp gauge should work as normal. There must be something wrong with the cluster or the green circuit board at the back of the cluster.
  5. NeilB
    NeilB New Member
    VR Caprice
    I'm pretty sure the Temp sender is different as when I asked about this cause I'm doin a V6 to V8 swap I was told to get a V8 panel as the Temp and Tacho were different. Sometimes you can buy them on Ebay pretty cheap or if you have your old 1 just swap the Tacho and Temp gauges with the new 1. It's not all that hard to do, or if you just want the 250Kmh speedo just put the speedo in your old 1.
  6. stocky
    stocky New Member
    yes you can. there is a resistor that needs to be changed inside the cluster. not sure which one it is but there are a few photos of it on this forum somewhere
