goldgem
- Mar 31, 2010
- 3
- 0
- 0
- vs calais
Mucking around with a 304 from a VN commodore thats fitted in a hilux, bit of a rough conversion as in wiring is messy but did run fine apparently. I have done the rear main seal and small tidy up.
Went to set the timing which is easy enough, will set to base timing but wont advance at all the timing just stays where i set it. this then causes pinging and back firing and lack of power obviously.
I have replaced the Ignition module with a recon one, still the same, I have noticed it gets hot burnt my hand a little bit, also checked that its grounded and ran a seprate ground to it aswell and still No good.
I was under the impression that the moudule is responsible for advance and not the ECU
Any ideas??
Any ideas??
