BLOWN-WH
- Mar 21, 2006
- 111
- 27
- 28
- Statesman-Caprice collection
Hi all,
My Caprice is getting close to the 60k kilometres mark so I'm thinking its time to complete a transmission service soon.
Im guessing the procedure is straight forward and same as its for a VE??
Remove/replace the filter, fill up 6 litres from the plug hole then start the car, change from Park to Drive a few times then while the car is still running and reached that normal temp top up the remaining 300ml of oil or at least until it starts dripping out from the plug hole?
My next question is the type of oil to go for??
Ive narrowed it down to either between Mobil Dexron VI ATF (https://mobiloil.com/en/automatic-transmission-fluid/dexron-vi-atf) or Penrite Multi Vehicle Full Synthetic ATV LV (http://penriteoil.com.au/products/atf-lv-full-syn).
I must admit though been having a real tough time trying to find anywhere here in Melbourne who is stocking the Mobil trans fluid.
Has anyone had good or bad experience with either of these two fluids in your VF's or would recommend something else?
Thanks in advance.
Thanks in advance.
