V8 & V6 strength differences?
Discussion in 'VN - VP Holden Commodore (1988 - 1993)' started by Pav, Feb 13, 2008.
  1. Pav
    Pav New Member
    WA Perth, Joondalup
    VS daily // V8 Hilux // Merc 190E
    Any difference in strength between v6 and v8 diffs?
  2. V85000i
    V85000i Member
    S.A
    VP 5L Calais
    yep, V8's are have shotpeened gears in them.
  3. Pav
    Pav New Member
    WA Perth, Joondalup
    What if I got a diff shop to shotpeen the V6 gears and would it cost much?
  4. greenfoam
    greenfoam New Member
    VP Executive R-spec
    Yep they are shotpeened but it could be debatable if they make any difference. You don't see anyone breaking the gears in any sane car anyway. I'm running NA VL gears in mine and they don't break
  5. V85000i
    V85000i Member
    S.A
    VP 5L Calais
    i doubt that is and option, shotpeening (someone correct me if i'm wrong) is when the gears are pounded with heaps of ball bearings at high speed tocompress the metal and make it stronger and i presume it is done before the gears are machined, so i don't think you can get 6 cyl ones done, but chuck it in anyway it might last.
  6. Pav
    Pav New Member
    WA Perth, Joondalup
    Ok, cheers, I just thought there was a large difference between them but thats cool.
  7. greenfoam
    VP Executive R-spec
    Nearly every fast V8 is running gears from some low power car with big ratios and they aren't shotpeened. Plenty of them running 12 second 1/4s or better on those gears so I don't think you will break it
  8. VLDavo
    VLDavo New Member
    lc torana. vn v8. ke30.mazda 1300.
    really wouldnt call 12 seconds fast anymore anyone with a gen 3 and few bolt ons can do that now lol
  9. HDT_aero
    HDT_aero Banned
    SA
    manual VN aero
    My mate in his stock auto v6 with simply a spooled diff managed to blow the gear teeth through the housing..... how ever he did snap two axles (wich obviusly were replaced) before hand. saying that the lash couldnt have been to crash hot after the first couple of axles
    Dont take it that makes them weak thow cause this diff took a beating and im very suprised that he didnt blow other things first.
  10. greenfoam
    VP Executive R-spec
    12 seconds is certainly fast for a 5 litre or a V6 :) which run these diffs, the gen 3's run the 8 inch gears. 95% of VLT's don't make low 12's either no matter how fast people think they are. I've see a 11 second torana with a VN diff break several axels and never hurt the 4.11 gears in it
    HDT_aero, A friend of mine broke the gear in his VQ but he ran out of oil so it doesnt count :), I'm sure you could break on with a big single spinner burnout until the spider gears weld their shafts and then snap off and THEN break the main gears, that happens. But that not really the fault of the main gears.
  11. V85000i
    V85000i Member
    S.A
    VP 5L Calais
    that brings me to another point, Are the spider gears and side gears shotpeened too in V8's
  12. tigervh
    tigervh SS.....smokin....!
    Newcastle
    Tiger Mica EFI VH, VZ SS, XC Barina SRI
    And they do it down Auburn St at 5pm hey Davo!
  13. sebstenator
    sebstenator Burn
    VN SS 5.0
    haha mate. dont waste your time. just get an LS1.
  14. 1991_Vn2nV
    1991_Vn2nV New Member
    Gumeracha, Adelaide Hills
    91 VN Berlina & 03 VY Berlina
    I've read on the other forum that they are yes.
  15. CSL
    CSL Member
    missus (in more ways than one)
    quick quesiton, i have a "high performance" diff so the tag says, and with the age old jack it up and spin the wheels lsd test it passes with flying colors, but is it really an LSD cause they released diff with "high performance LSD" on the tag, it does LS but i want to know so when i get the gears installed i'll ask em to shim up the lsd and make it tight again
  16. burnz
    burnz dah dut dut da dah
    springfield
    VFII SS ute M6
    shot peening is fasinating to watch.
    simply the metal is heated to around 900* and only one ball bearing is fired at it,
    it is easy to tell if it fail to temper or not,bye sight and sound.
    a ping is heard like a crystal glass and a shockwave is visable to the naked eye,(sortof like seeing a bomb shockwave)
    running from the center to the outer in a radius motion.
  17. greenfoam
    VP Executive R-spec
    Are you sure about that? I thought thousands of balls were shot at the metal to forge the surface layer?
  18. 1991_Vn2nV
    High performance tags are normally on live axle and the LSD diffs actually say LSD (i.e. the high performance LSD that you mentioned).
    But if it passed the test spinning the wheels i'd say its LSD.
  19. burnz
    springfield
    VFII SS ute M6
    for the diff's that's posable but for tempered saw blades 500mm dia
    only one does the job.
  20. V85000i
    V85000i Member
    S.A
    VP 5L Calais
    that's what i thought.
