vaccum gauge going in soon, instal help?
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
1995 VS Commodore v6 ecotec
where do i tap into the vaccum line etc? ive allready got the wiring sorted its just the vaccume line that i need to know about, also will i need to get an extention of the tubing?
also does having a vaccume gaue effect the performance at all? eg loss of vaccum?
thanks in advance
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
it wont effect performance at all as its sealed so it holds vacuam.tee into the vacuam line that comes off the manifold and goes into the firewall that goes to all the dash controls tee in close to the manifold as you can.
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
sweet as, got any pics?
PanthaVS
VS S-Pack SII
as if you are above the engine looking down onto it....
Tap the gauge (using the tee-piece) inbetween the plenum and the one-way valve... its very squishy near the firewall.... but it is there!
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
wicked, your a champ, thanks heaps!!!
should i use the same hole in the firewall that my other gauge senders are running through??
PanthaVS
VS S-Pack SII
you can run the vacc line anyway you like... depends on length of the line you have... but take this in mind... the shorter the length, the crisper the response....
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
sweet, any good areas aka holes in the fire wall to run it through (to the gauge??)
at the mo my oil temp and pressure is running through the clutch cable hole
ScoHar
Jizz in my pants
CHCH, NZ
VS Senator
I'd run it with your others in the same hole, keeps em nice and tidy and not all floating around.
PSYKO PHOENIX
AHHHH brain fart
Auckland, NZ
sweet, any need to heat shield it?
ScoHar
Jizz in my pants
CHCH, NZ
VS Senator
na vacuum hose is usually pretty heat resistant, just run it somewhere not too close to your exhaust.
