Vacuum advance outlet on Varijet II?
Discussion in 'VB - VK Holden Commodore (1978 - 1985)' started by VRSS, Nov 12, 2007.
  1. VRSS
    VRSS New Member
    Radelaide
    VX Clubsport R8 6-Speed
    hey everyone, ive recently swapped my black motor from E.S.T ignition to the HEI Electronic dizzy off a blue motor. My car has been in the mechanics and i've been told that i'll need to get the carby off a blue motor aswell, cause theres no outlet to run the vacuum advance off of.
    my question is there a way i can hook up my vacuum advance from the Varijet II carby on my black motor? or do i actually have to get a carby from a blue motor for it?
  2. Pub247
    Pub247 Well-Known Member
    Melbourne S.E.
    Ford Fairmont
    if i remember vkberlina site's has the diagrams for the vac system if you go there and look use one similar to the efi. I cant really remember how it was on my vh but similar to the efi
  3. VRSS
    VRSS New Member
    Radelaide
    its only 1 hose i need to know about, the vacuum advance from the distributor? is there a spot where i can connect that to and it will work or do i need the blue motor carby too???
  4. Not_An_Abba_Fan
    Not_An_Abba_Fan Exhaust Guru
    Bunbury, WA
    Strange Rover
    All you need to do is hook it to the inlet manifold somewhere. It runs to a direct vacuum feed off a carby. Usually towards the bottom there is a fitting that runs into the venturi of the carby. So any vacuum line off the manifold will work.
  5. V-ahhh
    V-ahhh Member
    SA
    VN/VT
    what he said ^^ there is usualy spare inlets to feed from well mine has.
