304 Valve Spring Upgrade?
ScoHar
Jizz in my pants
CHCH, NZ
VS Senator
Does anyone know the specs of the LT1 springs you can fit to these engines for an upgrade?
Specs I have found so far ar:
Installed Height 1.9"
Seat pressure 134psi
Open Height 1.250"
Open Pressure 424psi
Dia 1.460"
Does this sound right?
greenfoam
VP Executive R-spec
Are they the speed pro springs? I have the spec for them
ScoHar
Jizz in my pants
CHCH, NZ
VS Senator
They're the ones we sell at work PEP, specs on speedpro will give me an idea.
xx5047
vrss11
i know the good ol trw chev lti springs are good for 80,000+km with solid lifter .550 lift cam ,8000+rpm no problems.
RVK 355
M0DERAT0R
The real R series 355
Open Height 1.250"
Dia 1.460"
are they the specs for the LT1 springs?
oldmate74
VQ Stato
LT1 springs are good for cams up to 500-550 lift depending on the brand and are direct fitting. meaning only 1.250 diameter. installed height should be around 1.70 and coil bind should be at least .80"-.100" larger than the lift on the valve.
but they are a perfect spring for any hydraulic cam grind
see page 2 of this pdf under valve springs and look for part#4833
http://www.crowcams.com.au/media/catalogues/35.0 Holden V8 EFI.pdf
