VB Fuel Pump problem. no fuel getting to engine.
Vb paddockbasher
33
nsw
vb commodore sl 1979
i have a vb commodore as a paddock basher, recebtly just stoped, and it is not pumping fuel to the carby or the fuel filter.. where are the fuel pumps on these? are they in the tank? how to go about replacing one? if taht is the problem which im sure it is.
Smitty
Moderator
Bayside Melbourne
GenF SV340 R8 Tourer, VK race car, ZX12R
filters are next to the pump ..which is on the side of the engine
bjwynd
mortlake
vb sl
there on the block follow the fule line down there is two bolts holding them on
Tree cutter
Tree cutter
Mt Gambier SA
VX Calais SuperchargedV6
The fuel pump is bolted onto your engine and has an arm that runs on the camshaft to operate the pump. It is on the drivers side just in front of the engine mount and is held on by two bolts. You might have a stripped cam gear too. If the teeth are stripped off the cam gear which is very common then the cam wont turn so the fuel pump wont pump. Take the distributor cap off and wind the engine over so you can see if the rotor button is turning around like it should. If the rotor isnt turning then your cam gear is probably stripped.
