It is a lot easier to get power out of vn vt motor than the 308. The heads are far superior and the block is stronger. Inlet manifolds are readily available to suit the vn vt. Work out how much you are prepared to spend and go from there. My vh before I pulled it apart put out 200 rwkw. 355 vp v8 stroker. I kept the efi. 10.1 compression, Twin throttle body, ported heads, baby cam, tri y extractors, 3'' exhaust, 3.45 vl turbo diff. 4 speed auto. The car was quite economical. 2300 rpm at 100 k. As you will appreciate obtaining power even at these low levels is not cheap.
