vb to be vc satin black brock
ari666
250,000 hits
Castor out by mile looks like this / \
if you mean camber, undo your strut tops and rotate them back in their corect spot. there is a hole in your tower which wouldve left a mark on the strut top to tell you where it needs to be installed. if the 2 holes line up, then check you havnt put the LHS on the RHS by accident.
the strut tops are not symetrical. the center of the shock is offset and if the top isnt in the right spot, the struts angle can be + or - heaps.
Young gun
Dream BIG!!!
79 vb
Will my cut down vr strut tops rotate the same?
And does any one have a smart way to pump guards?
VK SL 3800
VK SL 5spd
Your strut tops wont be the same if you have positioned your studs evenly, the factory studs are eccentric to the strut hole in the middle giving you 3 different positions with different camber/ castor settings. Its a trade of because you compromise one or the other to get it as good as possible.
Can you post a pic of the front of the car showing how the wheel sit with the wider track?
Young gun
Dream BIG!!!
79 vb
Had it started about a week ago now
First start! Satin black vb v6 - YouTube
Now has a tail shaft ( vr man front vl rear) and a fuel tank need to re do feed line not happy with the one i did. 3 out of 4 Break callipers last one to go on tomorow ( just vr for now have vt callipers need some shims)
Have got a phatt cable out of a bmw at pick a part for batt in boot and a universal batt box, keeping it clean
Ill put some pics up tomorrow
Young gun
Dream BIG!!!
79 vb
It drives!!!
Tank and how fits in guards (finger tight) with camber not fixed
And the most important part
Satin black vb. first drive!!! - YouTube
Young gun
Dream BIG!!!
79 vb
I see red
Little by little bit by bit. Slowly coming together. Need some rubbers for windows and doors
Piecing interior together, has a L shape in gear selector unsure on how to seal from tunnel any ideas?
Young gun
Dream BIG!!!
79 vb
Lights camera action
Rear bar, tail lights. Soldered rear lights loom to the vn loom, after fuel pump, demist and boot 'pop'.
Was only me so dont know if break lights work.
Tail lights being a pain there not there, same with head lights and blinkers
Headlights have 12v power to globe but not working! Power to one terminal when globe disconnected, and powers all 3 when globe plugged in. Even when lights are turned off. But theres no light, tried 2 globes. Runs a head light loom from a vs.
Can any one shed some light on situation?
And haven't had a good look at blinkers would a lack of side ones matter?
VK SL 3800
VK SL 5spd
They use negative switching on the headlights.
