same as V8 Calais ?
Thanks for thatALL VK V8 sedans are the same....View attachment 218503are the same....
Thanks for that
Was told today that all group As had a pump in the tank
What can you tell me about these two pleaseView attachment 218510View attachment 218510View attachment 218510View attachment 218510
Sorry yes they are the same photo it wouldn’t let me attach the other one saying file to bigThanks for that
Thanks for that
Mines is missing , long story short it was taken out by a mechanic and lost I never seen it , I found one on line that they told me was out of a Vk V8 but doesn’t have a pump on it , a mechanic that has a group a told me his car doesn’t have a pump in the tank it just has a big outlet tube for fuel to the motor a thin outlet for the breather hose and a plug for the gauge@Chap1969 Hi Vin999 looks like you know a bit about the Vk fuel system just wondering what you can tell me about the Vk group a fuel sender please I’m trying to find one
Reading your posts don't make sense, looks like that old game of charades ..... guess what I got behind door 1
Perhaps you should tells us what's wrong with your fuel sender ?? why you are looking for 1 ??
Why ask for info if you can see the fuel sender from your car ??
That mechanics car would probably have been changed to external aftermarket pump/filter/lines setup and probably changed sender for maybe a VH V8 one as most 35 year old cars have had many changes done when small pump gave up.Mines is missing , long story short it was taken out by a mechanic and lost I never seen it , I found one on line that they told me was out of a Vk V8 but doesn’t have a pump on it , a mechanic that has a group a told me his car doesn’t have a pump in the tank it just has a big outlet tube for fuel to the motor a thin outlet for the breather hose and a plug for the gauge
Sorry for being a pain and thanks for any help
As smitty mentioned a crappy low pressure pump/different relay was used for start up with manual pump. Did you say you had a Calais ??? Calais would have had different connections on sender unit along with low fuel light/ trip computer ?? . Also see if you have a manual fuel pump/block plate down on the motor behind the alternator ???
no I don’t have a Calais , and yes I have a manual pump
ah ok
