VB-VL link pin kit for a VR?
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by stocky, Dec 3, 2008.
  1. stocky
    stocky New Member
    have been reading a few threads, and people have mentioned there was a kit available for VN's that allowed you to use a link pin setup from VB-VL, that connected to the control arm i believe. is there a kit available for VR/VS, or should i just go with the bent heavy duty ones most people have?
  2. immortality
    Sth Auck, NZ
    the standard VB-VL kit doesn't work on the VR because of the different lower control arms (cast instead of pressed steel) there is a kit that uses 'U' bolts to attach to the control arm instead of the strut but i've never seen one used. but it must be better then connecting to the strut in the standard fashion. the other new ones i've seen use balljoints in the link pin where it attaches to the strut and the sway bar so it pivots and doesn't load up on the steering like the factory ones do.
  3. stocky
    stocky New Member
    yeah i think it was your thread i was reading that got me thinking about it. i dont know where i would find one of these kits, and ive heard VR ones are expensive.
  4. immortality
    Sth Auck, NZ
  5. stocky
    stocky New Member
    hmm i can find the older one on the nolathane site, but nothing about a VR style kit. will keep looking
  6. immortality
    Sth Auck, NZ
    check link in my post above
  7. ScoHar
    ScoHar Jizz in my pants
    CHCH, NZ
    VS Senator
    Whiteline also make a VR conversion, consists of a U bolt that goes around the lower arm with a bracket on top that has 3 holes of adjustment(maybe for different swap bars) and then goes upto swaybar. Ill try get the number for you, but the VR conversion isn't as pretty as the VN type conversion where there is already a hole in the lower arm.
    *edit number is KLC18 whiteline product
  8. stocky
    stocky New Member
    hmm the whiteline ones are hard to find, and over $100 for something that looks pretty simple
  9. axemurderer101
    axemurderer101 Well-Known Member
    Albany
    VY SS
  10. stocky
    stocky New Member
    yeah thats it. whered you get that and what did it cost?
  11. axemurderer101
    Albany
    VY SS
  12. stocky
    stocky New Member
    awesome thanks. now i need to decide if its worth the extra 70 haha
  13. ScoHar
    CHCH, NZ
    VS Senator
    So there is another option for lower arm sway bar mount conversion??
  14. stocky
    stocky New Member
    yeah theres the ebay link above which is the same thing you mentioned. its $100 on ebay
