weekendwarrior22
- Jan 16, 2021
- 11
- 0
- 1
- Age
- 51
- Location
- victoria
- vc commodore
will a heater core from a wb fit into a L model vc commodore with air con?
Thanks
Grant
Thanks
Grant
cant say for sure from memory, early vb/vc had different core placement/air con to last VC's built same year to VH and changed air con. Big mess, bypass heater core and wear more clothes
I looked at the compressor it has SANDEN on the tag and its silver colour... I think its and aftermarket system, Ive never known my heater to work with the air con, it just blows cold air whether the heater is on or not, so I think i dont have to de-gas/re-gas. does that sound right to you?cant say for sure from memory, early vb/vc had different core placement/air con to last VC's built same year to VH and changed air con. Big mess, bypass heater core and wear more clothes
i found one but when i tried to buy it it was suddenly out of stock and been out of stock ever since... all the others ive found have been for hz hx hj hq and WB which is the model before vb commodores i cannot find a vc vb heater core, If you can find one please, point me in the right direction.I looked at the compressor it has SANDEN on the tag and its silver colour... I think its and aftermarket system, Ive never known my heater to work with the air con, it just blows cold air whether the heater is on or not, so I think i dont have to de-gas/re-gas. does that sound right to you?
no it has blown out or something my whole passenger side floor was flooded with coolant.Is the core blocked, does coolant flow through the core? Try reverse flushing it for starters.
[Can you not buy a VC core new?
