VC weird electrical issue
Discussion in 'Electrical Wiring / Questions' started by vc commodore, Sep 16, 2018.
  1. vc commodore
    vc commodore Well-Known Member
    south australia
    vc commodore
    Hope someone can point me in the right direction....When I have my headlights on and brake, with my right indicator on, it stops flashing.....Without the headlights on, there is no issue with it flashing when I brake...The left hand side is fine under these conditions....
    Where should I start looking....Oh and it is a serious thread, not some sort of joke.
    Thanks in advance
  2. rambunctious
    rambunctious Well-Known Member
    Mooloolaba
    VZ Wagon
    Redo the earth to the radiator support for a start.
    Then look at all bulbs for correct fit/correct bulb/and good earthing.
  3. yamahahatim
    yamahahatim Member
    Central Vic
    vz ss crewman
    Not 100% what's happening, but I'd check all earths possible. Even globe holders...
    Had some weird stuff go on myself, with an old hz ute I have...corrosion in blinker housing caused total brain damage!!!!!
  4. the_boozer
    the_boozer no more VK
    morwell
    Prado
    if it does the same with just the park lights on, tail light earths is where Id start looking , its an earthing issue
  5. vc commodore
    south australia
    vc commodore
    Thank you everyone for your replies.....I'll start with the earths and move on from that, until I get the problem solved.
    @the_boozer ......I didn't check to see if it happened with the parkers.....I just noticed it happening when I was driving home last night, with headlight ablaze...So it gives me a good starting point
  6. vc commodore
    south australia
    vc commodore
    Just an update...Had an earth at the right rear taillight that was freyed.....Cut it back, put another electrical connector on and everything works as per normal....So thanks for the replies and hope it helps someone else in the future
    yamahahatim likes this.
