VE 10 inch REAR
Discussion in 'VE Holden Commodore (2006 - 2013)' started by DjSunnySun, Apr 12, 2013.
  1. DjSunnySun
    DjSunnySun New Member
    NSW
    Holden Commodore Series 2 Superchaged
    hey guys , ive got a VE sv6 & ive gotten new rims for it off my mate ,
    there 245/35/20 - which fit the front perfectly
    to fit the 275-30-20 , i wanted to know what stuff would i have to do to make them fit the rear ?
    i know i gotta get the guards rolled , but what else ?
  2. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    shouldnt need anything, main concern is what offset are the wheels, this is where it could cause it to stick out too far and rub guards etc or push inwards and rub inside of guards(against body), somewhere around 42-48 should be ok
  3. Heron SSV
    Heron SSV Active Member
    Central Coast
    I have 285s on the back of mine with no issues, but that's with stock suspension. I have noticed that I've got less grip now than with the old standard SSV rims for some reason... Might be crap tires though
  4. lease1
    lease1 New Member
    SSV Ute
    Have 20 x 10 with a 48 offset with 275 30 20 and kings SLHD on my ute with no scrubbing, even with a heap of weight in the back
  5. Sean880
    Sean880 Well-Known Member
    VIC / NSW
    2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
    A common reported problem with lowered VEs on 9.5 or 10 inch "aftermarket" REAR rims and 275 tyres is the rear tyre fouling the bumper bracket that holds the rear bumper to the body. It depends on the offset of the wheels you have but if the offset is so low that you have to roll the guards to stop the tyres fouling then is is very likely you will also run into the bumper bracket issue. Some people remove the bracket and modify it whilst others shave it down so it just clears the tyres under full suspension travel. I have also seen some peeple reporting the need to do this to prevent rubbing even though the large enough wheel offset has not required them to roll the guards when running 275 tyres. HSV085 with his lowered E3 Clubsport and 20 x 10 inch aftermarket rims /275 30 20 tyres was one member that mentioned this - bumper bracket issues but no guard rolling needed with his particular wheels.
    I would not rush in to rolling the guards until you test fit the rear wheels with tyres to check your guard clearances each side. If the wheel offset is high enough you will clear the guards with 275 tyres (but many 10 inch aftermarket wheels do not offer a high enough offset for VEs).
    What offset number is stamped on the rear wheels?
  6. brasher
    brasher New Member
    Aus
    VE SSV Ute
    grab dremel, grind down the tab just before the screw, file smooth.
    Still rubbing roll guards
    still rubbing get a bigger hammer.
    You can make anything fit :)
