VFSV6FORME
- Mar 9, 2016
- 2,603
- 1,272
- 113
- Age
- 74
- Location
- Brisbane
- WN Caprice V 6.0L, VE Anniversity V6 Series 1
Well the VE V6 Anniversary has had 22 Starts in the last week or so and The Vents on the Air Con have preformed without a issue. For the First time I can say It not repaired but we have a way of getting around this issue where when you select the FACE Vents and no air come out 1 in 5 times (sometimes worst) whenever you start the car and when you need cold air on your face NOTHING COMES OUT and this alone is very frustrating.
To Fix this issue I have used a working HVAC Module from another VE that works Perfect on that car, I also have used a Facia from the Working car that works good on the car that is effected with the face vents not working but it still fails So what I did I put the original HVAC and The Radio Facia back on and done this ::::
VE Commodore Series 1 and 2, tested on Single Zone but could work on a Dual Zone
Before you turn the car off you do.
1/ Leave the Vents Selector set to FEET ONLY, Yes Feet Only
2/ Turn the Air Con off either Hot or Cold. My VE its the middle button for series 1 Anniversary or Omega, when you turn the air con off the LED goes out.
3/ Then I turn the Fan off which seems to be the Main switch.
4/ Now the next day or later, the same day you want the use the car and the air con, so what you do when you get into the car you check to see if the vent selector is still in the position of feet only, put the keys in the ignition, start the car, start the fans on any speed you want, turn the Air Con on and finally select/change the vents from the feet to the face and you are away and when you are finished with the car dont forget to put the Vents to FEET ONLY.
Now I have to thank Member mikeryantipp as he was the one to find this combination to get this outcome as I tried at least 10 other combinations and in all case the combination FAILED but this combo leaving the Vents set to FEET ONLY its perfect to get around this issue.
After this I can put My Glove box Back. Yepeeeeee
Also Member mikeryantipp leaves the fan ON and sometime the Airc Con on Too.
The Main thing to do is LEAVE THE SELECTOR FOR THE VENT TO FEET ONLY BEFORE YOU TURN THE ENGINE OFF.
