VE 2009 Not Starting Nice When Hot
Discussion in 'VE Holden Commodore (2006 - 2013)' started by Nightfox187, Jan 21, 2017.
  1. Nightfox187
    Nightfox187 New Member
    cairns
    09 VE SV6
    Hey all
    I have a 2009 VE SV6 with 160***ks been well looked after oil change every 5k and in the shop every 10k
    So my problem is she start ok when cold or sitting longer then 4ish hours but when she is warm is start but it like it not getting Fuel/Air or something it start just it is not happy. it revs really low like 300ish and like the engine is running backwards making a very weird clunky sound for about 1sec or 2 then it is ok again and drives fine. it is hard to explain what is going on if anyone know or has the same problem please help me :/
    I just order a RYCO Z888 VE fuel filter/pump to see if it is that.
  2. Gtx2
    Gtx2 New Member
    Ve ss thunder
    Try looking into a coolant temp sensor if your fans are acting wierd aswell
  3. blackve76
    blackve76 Well-Known Member
    there
    VE SS ute 360rwkw N/A, 2016 VF2 SS M6
    sounds like fuel issue like vapour lock, mine at 155K(same servicing as you) sometimes cranks a bit more before firing but runs great.
    When were plugs changed?
  4. Nightfox187
    cairns
    09 VE SV6
    i change the plugs about 10k ago :) i was thinking fuel as well
  5. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    you have to remove the tank to fit this
  6. MYVESSV8
    Brisbane/GoldCoast
    VE 6LT M6
    clean maf tube and maf
  7. greenacc
    greenacc Searching for the billion
    VE Berlina
    Unlikely to be fuel pump if it starts ok when cold.
    Does it blow any smoke when it starts rough?
  8. Gtx2
    Gtx2 New Member
    Ve ss thunder
    Try letting it sit for 4ish hours as u say so cold start should be fine the turn off say a minute after then start again so two cold starts. What happens. Did have exact same problem but different ute took me ages to pin it down coolant temp sensor does some how control air fuel
    Do u need to floor it to start it when hot and backfires once it cranks
  9. redvxr8clubby
    redvxr8clubby Active Member
    Sunshine Coast QLD
    VX Clubsport R8 & VE SS
    Coolant sensor sounds reasonable, but I would think if there is no change in coolant temp after a while, that you should get check engine light and some codes.
  10. Sean880
    Sean880 Well-Known Member
    VIC / NSW
    2012 VE SV6 ser 2 and 911 Porsche Carrera S 997
    Just throwing parts at it , and hoping you will stumble on the cause, is not the way to go.
    You have not mentioned if you get a check engine light displaying on the dash display at any stage.
    Putting in a new fuel pump will almost certainly not solve the problem you have described and it is a hassle to do because to fit the in-tank pump unit requires the fuel tank to be removed from the car as another poster advised above. By all means have a new pump fitted but, given the symptoms you have described, you don't appear to have a faulty or weak fuel pump.
    You need to get the car to a mechanic and have him check it out with a scan tool. The problem you described is probably generating a fault code or codes and this should be stored in the system and can be retrieved. If not stored then, given the symptoms, some fault code should nonetheless show up when starting the engine when hot if it performs as you say it does. Then you can begin to trace the source of the problem. I would also be having a look at the short and long term trim fuel trim readings (again with the scan tool) and see what is going on with your engine.
    From your description it sounds like on a hot start the computer is getting a false reading from some source and too little fuel is being delivered, the engine just barely starts and barely runs on a very lean air/fuel mix for a few seconds, and then it apparently corrects and the engine appears to be running normally again. Anyhow get a professional to check it out . It is possibly going to be something straight forward to rectify if you have a competent guy doing the diagnosis.
  11. carcollector
    carcollector Member
    WM Caprice, VZ SS Crewman
    Mine has done similar on occasions, and I suspect the purge solenoid, based on a couple of posts.
    This post from delcowizzid sounds plausible;
    this can happen when the purge solinoid for the carbon canister dies and isnt sealed when the ecu is not commanding it to open.you fill up and goto start the car and it takes a gulp of raw fuel out the vapour line from the real full tank putting the vapour line under the fuel level
    and this one from Michael-08-VE describes where the solenoid is.
    The purge solenoid is on the passenger side sitting just next to the intake manifold, it might make a ticking noise every so often, you'll notice a hose leading under the manifold towards the throttle body, trace it from the throttle body, under the manifold and back to the solenoid, sorry for the shitty description. Long day.
    If your car won't start with normal autostart cranking, try pumping the accelerator like you would with an older car that's flooded. If it starts OK that way, then I'd say start with the purge solenoid. Mine does it very occasionally when I fill it up and it's hot. Pumping the accelerator while it's cranking always gets it started.
  12. PORKSTER
    PORKSTER New Member
    adelaide
    ve sv6
    Anyone one have any joy with this problem... Plus this error doesn't generate a fault code had it checked... Ill try the purge solenoid
  13. Kingcarl
    Kingcarl Active Member
    VE Sv6 series II MY 12.5
    Id try the Purge valve mate, mine was doing the same thing and it fixed it.
    PORKSTER likes this.
  14. kyone
    kyone Member
    2007 VE CALAIS V
    My car has the exact same problem.. I have twice asked mechanics about the purge solenoid valve and both said "I doubt it very much"
    I have my car booked into a fuel specialist on 5 Sep.. hopefully I can get it sorted once and for all. He was one that I mentioned the fuel valve to.
    Things other have found..
    bad solder joint in ECU .. replaced ECU
    Crank angle positioner sensor... I tried this replacement .. didn't fix the issue.
    Throttle body cleaned out.
    One thing that I have done is avoided the bio fuels.. I now use 95.
  15. PORKSTER
    PORKSTER New Member
    adelaide
    ve sv6
    Evaporative purge solenoid....... Problems solved
  16. Happydaze
    Happydaze Happydaze
    GC
    VH SLE T30
    Had a similar issue on my LS2, would start fine and run fine when cold. Once hot it was very difficult to start and ran like a pig. Let it cool down enough and it was good to go again.
    Put the scanner on it and got Crank Angle Sensor fault. Booked it into mechanics, they said it was a common issue. Ended up being weak starter motor throwing the Crank Angle Sensor out (when hot). New starter motor and all is good.
