Ve 2009 SS new issue
Chappy's SS
62
Shepparton
VE SS
Hi all, the other morning my 2009 Ve SS Started running rough then Check engine light, stability plus esp light. Stopped engine took battery lead off for ten mins. restart car, runs smooth with no warnings. Battery seems ok, starts well but not sure what is going on. John
vr304
Auckland, New Zealand
2007 ssv manual
Had this happen in my ss before never found out why although it could be a weak battery
markovr
62
northside brisbane
youtu.be
07vessv 94vr .04vz wgn,93vp wgn,82 vhV6 wgn 88 vn
I left a spark plug lead off by accident and it did all those things that happened to you
seveprim
VN
seveprim
VN
Did it do it on a hot day ?? The problem is the Crank Angle Sensor relies on "Hall Effect" and magnets lose field strength in heat so after a few year the sensor fails due to internal magnet failing... Hot Days cause your engine to run hotter then normal and hence the problem... Mine did the same thing yesterday 35c+ and had this problem in past on various models.
Chappy's SS
62
Shepparton
VE SS
Mine does not run hot, have noticed that the kms per 100 is changing a lot especially when the engine light is on. picking up a tester tonight to see what codes come up. John
Freedon
queensland
vu ss
check the maf sensor connections, if it vibrates loose it will do all that as well
Chappy's SS
62
Shepparton
VE SS
Hi all, well it turned out to be an open circuit In the injector itself. new Injector fitted all fixed, codes gone. Thx all John
