Ve 3.0l sidi error code P0300 , any ideas??
Discussion in 'VE Holden Commodore (2006 - 2013)' started by ozjet400, Jan 8, 2018.
  1. ozjet400
    ozjet400 New Member
    Newcastle
    VE commodore , Mercedes CLK500, Lexus GS300
    Hi guys.
    I have a 2010 VE Commodore, 3.0L Sidi , it’s throwing up an P0300 code ( engine light coming on) the car still runs fine, no misfiring, I took it for a run today to see if I could make the engine light come on, I found when I put it in manual shift, I fine the light comes on at around 3000rpm when backing off, coming back down in rpm... due to no obvious misfire , I’m hesitant to think it’s a coil or a plug, it’s got 150.000kms on it, I’ve checked the coil wiring earth straps, cleaned them up
    Any assistance would be appreciated
    Thanks in Advance
  2. h8tensv6
    h8tensv6 Active Member
    Newcastle NSW
    2009 SV6 2002 VX 1989 VN 5 Litre
    If you google p0300 for Ve it says random misfire. You said you don't have a misfire so could be anything like loose wire or faulty sensor causing it. Mention it to Holden next time your car goes in for a service or work and see if they can find the fault. There are that many sensors on Ve engines it would be hard to trace it yourself unless you were and electronic genius. What fuel are you using. We found the wife's omega with the 3.0 litre coughs and splutters a bit on e10 but not enough to send off any alarms. Doesn't do it on 95 or 98.
  3. ozjet400
    ozjet400 New Member
    Newcastle
    Thanks for your reply.
    Yeah, if it has a misfire, it’s not noticeable, I generally run 91 or 95, however it’s had around 2 tanks of e10 in it over the past 6 months, I tend to agree about it being an electrical connection, sensor, I’m about to put new plugs in tonight, I don’t think that will be the issue,as it’s go 154000kms on it, I doubt they have been changes, plus I can have a look at the plugs
  4. VS_Pete
  5. ozjet400
    ozjet400 New Member
    Newcastle
    Hi,
    No, I haven’t had the car from new, second owner,
    Thanks for the link, I’ll check it out
    VS_Pete likes this.
  6. VS_Pete
    Have the O2 sensors ever been replaced.
    Should be replaced about 80000klms.
  7. ozjet400
    ozjet400 New Member
    Newcastle
    Hi. I looked at the live stream data on the scanner tool. And got the following.
  8. RiCeY
    RiCeY F O R U M W A R R I O R
    Australia
    VZ SV8 6spd 6.0 470rwhp
    May be carboned up intake valves, this will cause intermittent misfire. As SIDIs are direct injection the fuel doesn't pass through the intake valves so they slowly build up carbon till it actually stops the valves sealing properly and results in misfire. You can pop the intake manifold off and look down the intake runners with a torch and you will see if the valves are caked in carbon.
  9. ozjet400
    ozjet400 New Member
    Newcastle
    Hi.
    I have taken the intake manifold off. Looks good in the intake ports for carbon. I cleaned what was there up
    I was messing around with it today. I had the maf senor unplugged. (It had maf codes). But no p0300 and ran much better. Might be a dodgy maf. Or not having it plugged in could of masked the issue
  10. VS_Pete
    Did you clean the maf with maf cleaner
  11. ozjet400
    ozjet400 New Member
    Newcastle
  12. ozjet400
    ozjet400 New Member
    Newcastle
    I just replaced the coils. New plugs. New 02 sensors ( all 4) cleaned the MAF with the correct cleaner. Checked the intake for carbon. Cleaned the throttle body out. Went over every single vacuum line. Even sprayed carb cleaner around every vacuum line and joint to find any vacuum leaks
    Battery voltage over 13v when not running. 14.3 when idling
    I hold the throttle to 2500- 3000 rpm while stopped In park. the P0300 code still appears .. the engine sounds great. No misfire
    I am now getting a brake and abs fault light. While the car is not moving... and these faults don't come up on the scanner... just the P0300
    Any advise welcome
  13. RiCeY
    Australia
    Does your scan tool show a misfire graphic so you can see which cylinders are misfiring? You won't always feel misfire.
  14. ozjet400
    ozjet400 New Member
    Newcastle
    Hi..
    It might be a dodgy alternator
    Ive been just checking the voltage at the jump start points under the bonnet.
    It can fluctuate between 12.5 to 15.2 v at idle
    Seems to be erratic
  15. Danny-VE
    Danny-VE New Member
    2011 Copmmodore VE Series II 3.0L V6
    I'm having the same symptoms:
    1. The princess highway in Adelaide has a steep descend in to the city and I usually run the engine brake so that I don't cook the brakes going down. After about 2 minutes I start getting check engine and the Stability Control OFF warning but it goes away after returning to normal driving conditions on the flat.
    2. While sitting at the light the engine starts having a slight tremor and feels like it is skipping explosions but no CEL.
    3. Fuel consumption seems to have increased a bit and also seems to loose some power.
    4. When I start it from cold, it idles high much longer that usual before returning to normal idling RPMs
    Had it in the service and they, supposedly, replaced my spark plugs, cleaned the valves and check the compression, etc... but nothing.
    I am now suspecting either a vacuum leak, the EGR valve or the coils. I posted a question on the forum to find out where the EGR valve is and maybe obtain a manual so that I can take it out...
    Any other updates, have you located you cause.?
    EDIT: Forgot the car... 2011 Commodore VE Series 2 Omega, 3.0 V6 SIDI.
    EDIT 2: Forgot the ODB Code... P0300 and nothing else.
    Thank you,
    Daniel
  16. VTS5
    VTS5 TechJunkie
    Sth.East\Melb
    VE OMEGA 3.6L Dual Fuel
    Just replace the coils.. Cause 9 out 10 times coil/s is the culprit.
    VS_Pete likes this.
  17. VS_Pete
    I sent OP a PM hope he replies.
  18. Kevin Galloway
    Kevin Galloway New Member
    Benalla
    Ve v6 Commodore. HSV RPA
    Hi,sorry to tag along but have same P0300 fault. Just did an engine change and getting misfire code on cyl 2,4,6. Have noticed no check engine alarm on initial start up, it comes up after idling for 10 to 20 secs.
    I'm not sure what alarms were on before the engine change as I didn't drive it.
    Can i swap sensors on cats to check if one is faulty?
  19. syked
    syked Donating Member
    2011 WM Caprice
    If you have the misfires on 1 bank it might be something like a harness which connects the coils or injectors.
    But have you checked / replaced all spark plugs
    You can also change the coils from one side to the other side of and see if the fault follows the coils or the stays on the same bank.
    Misfires aren't really related to post cat O2 sensors so no point looking there.
  20. Kevin Galloway
    Benalla
    Thanks syked, I got my son to have a look to see if he could find something and he found that I had left a small earth wire that bolts onto the head, it appeared to be bolted but it was only resting against the head.
    Car runs fine now.
    syked likes this.
