My Aircon only blows/works on legs and the windscreen when I start the car but if I turn the car off and back on it'll work on the head setting, what' the go??
try the relearn setting , be warned it can make a 1/2 functional air con not work at all ... most probably a faulty actuator ...a common problem cheap & not overly hard to DIY .
Mine was similar. Did face only not feet. Actuator was $50 on ebay. Fitting was hard as it is in a bad position and you need a 90 degree ratchet screwdriver. All good now.
Autoinstruct was a great help.
