Hi everyone, haven't posted for a while, and some help would be much appreciated. I still have the VF SV6 Storm Sedan Series 1 - June 2015 build.
My boot light is intermittently lighting when the boot lid lifts up.
Is there a "tilt" or some type of switch in the boot lid somewhere? or is there some electronic trickery hidden in the boot release mechanism wiring and/or the body computer?
What fuse, and where, isolates the 12V power to the boot lamp holder and/or the boot release mechanism?
Finally to get the lamp holder out, is it a small fine blade screwdriver to lever it out?
Thanks in advance for your help.
(I accidently flashed my VZs boot light wiring to earth when measuring voltages etc. prior to adding a couple of small LED lights to brighten the boot storage. I didn't blow the fuse. It upset the engine computer and weird things happened. I had to isolate the battery to get things settled down. This time, I would prefer not to go splashing the direct 12v or switched computer feed, ECU BCM or whatever, to the lamp housing in the VF.)
