VE Brake Light Not Working
archie95
VE Omega
Hey guys,
So all of sudden my rear left brake light has stopped lighting up.
I found it weird that it stopped working as Holden recently replaced it about 2 months ago, and before the replacement I had changed it about 3 months earlier...
So today I went out and bought a new set, plugged in and it lit up.... As I went to put it back into position, it just turned off.
I then tried to taking it out and putting it back in... didnt work
Neither did the other bulb...
For some reason the Right side does it as well, however this time it was working perfectly fine...
I checked the wiring and it all seems to be wired up correctly...
Kinda pissed that its not working....
Would really appreciate it if anyone has any suggestion on what may be wrong or how to fix it
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
could be the lamp holders are a bit dodgy, check your fuse as a bad connection (dry joint) can fail under load when it cools down come good again
